Sirpent
Everything posted by Sirpent
  1. Thanks for the thumbs up NZ, And if after the prototype is finished, and the first ex-mold example is fitted to the car and there is enough interest, I may call on interested parties to put their hands up for a production run. Cheers John
  2. Thanks Hunter, Thats the intention, to put it into production, this mock up will be smooth as silk on the outside, just dont look underneath.......LOL It will be used to make a master mold. Cheers John
  3. Cheers Rev Just cant wait to start re-enforcing the insides and then shaping the outside with fibre, then we just may see one eventuate.
  4. Thanks Brab, I have been under the pump at work and at home of the past week, house renovations at the Mother-In_laws all last weekend, a daily drive car that was leaking coolant from the rad and a stupid pipe located under the intake manifold, Yeah the whole lot had to be removed to get to it ! Anyhow, today was the first time I have had a chance to work on the front, and I want to finish this first before moving back onto the rest of the car rather than mucking about trying to make it all fit pre-paint, so today I did a whole lot of micro-adjustments to the entire nose, shifting things about in mm's so that I have both the left and right sides measuring up the same and then moved on to re-locating the wheel arches on each side so that the nose will line up with the guards. Now I can really see what the final product should deliver, with the cut-aways from the original lower end now re-positioned on both the left and right hand sides, the nose dosnt look that long anymore and really comes together a hell of a lot better. Anyhow will let you guys be the judges. Also I realised that I have enough meat there that I could incorporate brake cooling ducts on the sides, thoughts anyone? If I can get my hands on some fibre sheeting and resin tomorrow, Australia day looks like an interesting day to start molding it all together into one. Cheers John
  5. Welcome and congratulations Cheers John
  6. The following are pics of the VW Passat Lamps I purchased, the actually arc's are almost 100% on par with the bar shape, they will be fitted one either side into dressed cavities I will build into the bar just above each air duct, you will be able to bolt these in and remove replace as required. The effect should be a further reduction visually of the head lamp bucket / bar vent area giving it an even sleeker profile and look. Cheers John
  7. Brab, The original G-Nose came in 5 pieces from memory and were are perfect factory OEM part that bolted straight on. Most replicant G-Noses that I have seen on the market these days are 3 piece jobs. The one you see me building is a one piece that will include 2 internal moulded in re-enforcements from which I have determined I will use 6 adjustable brackets which will bolt the upper and front of the nose to the original bar mounting points, the bonnet hinge mounting points and a bracket either side securing the wheel arch sections to the inner wheelwell / skirts. To answer your question howvere, Im designing it so you can unbolt your entire front clip and bolt this straight on as a replacement. Any more questions feel free to ask. OH and I forgot, Im using slim line 2009/10 VW Passat front marker lamps, will take a pic of the one I picked up and post on here. Cheers John
  8. Thanks Gravice
  9. Thanks REV. By the way you are about to get a PM from me. Cheers John
  10. Ship it back to Japan, I hear they are paying top dollar to get them back now, and it's RHD so a bonus for them.
  11. Brab, The G-Nose isnt aerodynamic in its original form as far as down force, and becuase of it's 1970's basic shape, as far as the lower valance area, dosnt do much for the overall asthetics of the car making it look even longer and cigar shaped. Im attempting to bring a more contemporary look to it, deliver some downforce advantages and also utilise the intake ducts so as to force feed an intake plenum for the 45DCOE Webers Im putting on, so at speed there is a positive pressure available to the carbs when they open up, you could call it similar to a meager super charging of the intake. I also plan to use a splitter on each intake so as to deliver 20% of the air colected to front brake ducts, i.e. 80% to the intake chamber, 20% to the brakes. There are covers available at between US $600-$800 from what I have seen, but I wont be fitting any. The following pic (Sorry about the quality as I had to reduce its size to Buggary) should show the differences between what Im attempting and a generic original design G-Nose from the 240Z era. Cheers John
  12. Bro, Now our cars look the same too........LMAO Looks great apart from that tail lamp upper section. Your floor looks great now also. Cheers Your evil twin.
  13. Hey Mick Sorry to hear about the accident, chin up Dude....... Cheers John
  14. If this is what you want, then an almost identical color used here in Australia by Ford on the LTD series back in the 80's which looks fantastic as it has a high metalic component that really flares in natural sunlight was the following I painted an XC utility in this many years ago and it looked awsome. FORD MOTOR COMPANY NUTMEG METALLIC COLOR CODE: Q Go down to a panel shop and ask to see their color swatches and check it out. Cheers John
  15. Theres an eastern European bloke out in Melbournes outer east who does this kind of work. Lurcher Automotive P/L Cheers John
  16. Stay the path Mick, If you get tempted remember just look away, slowly turn around and run, run as fast as you can.
  17. Based on the previous comments, I couldnt help myself and went and pulled half my shed apart to get to the bonnet and sit it on the car, hope it's appreciated, at least I can sleep well tonight knowing it's right...........LOL Remember its not on hinges or adjusters, just sitting there as is. Cheers John
  18. Mick ! FFS, finish one first ! LMAO I know were there are 11 of them..............PM Me
  19. You may get your wish, Fraser and Alan from Alfa rang me today after I emailed them a set of more complete pics and it looks like they will put it into production.
  20. Your observation is correct, but remember that the line you drew is actually at the bonnet centre line / apex, the bonnet actually falls away from the centre towards the guards thats the reason for this illusion, The bonnet will be fitted when I next get stuck into it and will post pics to show that it lines up. Just working on a hinge design at the moment and I think I have cracked it after looking at the action of a pair of multi / vice -grips which allow one of the arms to to actually tilt back while travelling the upward arc sweep, this should allow me to build a set up that will allow the bonnet / nose section to have a natural factory looking gap. Cheers John
  21. Congratulations and welcome to the Dark Side.
  22. Thanks Buddy appreciated. I think ppl thought I was nuts when I first posted the original photo shopped pic about 5 months ago, but now that I can physically see it Im very happy with it, hopefully Fraser at Alfa Sports will be also as he said if it looks anything like the pic I did and the fit up of the final mock up is good, they will put it into production so it wont be a limited one off.
  23. Hers a side on shot of the actual height, dosnt seem so bad from this angle, you can also see how much it has to be extended back by to meet the wheel arch.
  24. Thanks Mick, It looks very low, but I have lined it up with the height of the sill panels, guess the reason it looks so is that the nose slops so much due to the upper "Alfa Sports" G-Nose section I used that is makes it look a lot more beefy, when I first self tapped it all together I thought no way to low, but then I looked at it from a number of angles and realised why, plus this really fixes the thin long look of the original G-Nose and gives it some volume. I know that it will still be a problem with speed humps and steep driveways, but this is going to be my cruiser not daily ride so hopefully with some caution I should be right. I can however slice it again just below the intakes and take another 5cm's out to lift it, but it looks so sweet from the side when you see it line up with the sills on a string line I ran. P.S. Mick, when are you going to write that tutorial on paint stripping?
