try this it solved my problem
p.s u can use other ones too i just bought these cause they look pretty
HKS Universal Circle Earth System
Circular Grounding System
By utilizing a 24-karat gold-plated distribution block and multiple grounding points, improved idle and drivability are often obtained as the additional grounding points equalize resistance and voltage between various ground points. Each 8-guage spiral twined cable is wrapped with signature HKS purple plastic to protect and add color to the Circle Earth System. Vehicle-specific kits include pre-measured cable lengths and distribution blocks. The HKS circle plate allows for the freedom to choose the thickness and the number of wires (up to 24 lines) to be used. Depending on the specific application, either the Separate Type (remotely located from battery terminal) or the Direct Type (directly mounted onto the battery terminal) is utilized.
24K-gold plating and high quality wire - Each of the eight SCQ wires consists of 658 winded 0.12mm lines that allow each wire to withstand up to a maximum of 65A.
hope that helps your problem
