juz0 Posted November 25, 2012 Posted November 25, 2012 Hello everyone I've been replacing the bushes in the Z with urethane ones. The kit I bought didnt come with instructions so I later found out that I needed to retain the original bush shells for the trans cross member..... after I'd cut them out, thrown them in the bin and the garbo had taken it all away. Does anyone have a spare with old bushings that I can buy off them? thanks Justin Quote
NZeder Posted November 25, 2012 Posted November 25, 2012 FYI a manual 280zx cross member is the same too Quote
garvice Posted November 25, 2012 Posted November 25, 2012 I'm pretty sure I still have mine, will go check tonight for you. No cost if I can find it. Brad Quote
garvice Posted November 25, 2012 Posted November 25, 2012 Had a quick look tonight and couldn't find it. I'm sure it is there as I don't normally throw car parts out (still have the useless drive shaft). If no one else can help you i.'ll do a better look later in the week. Brad Quote
juz0 Posted November 25, 2012 Author Posted November 25, 2012 thanks guys. I'll try chasing a 280zx one too. The only other thing i was thinking was getting some pipe turned down to fit. might be the go if I cant get a cross member Quote
