Hi guys my 1/4 window is starting to split the frame on the bottom corner. I assume it is rusting from the inside, but I also thought they were stainless steel?
Anyone had this before or know what the problem is?
Cheers, Gareth.
The outer part is stainless but there is an inner bracket holding the outer together. The bracket is just steel but the good news is it is just a right angle so making a replacement should be straight forward.
I just tig welded the inside corner of the frames together. Super strong.
I have a complete set of 1/4 windows seals for sale if you are keen.
  • 3 weeks later...
