PeterAllen Posted August 13, 2012 Posted August 13, 2012 I am fitting a fibreglass front guard/fender, however, I am securing the botton edge about 50mm out from the original mounting points - incorporating a new wider sill/rocker - and I need to make a new splash shield. I don't have an original guard/fender and the workshop manual doesn't show any splash shields. Is the shield attached to the guard/fender or is it a separate item which attaches to the main body? I think it might be part #81 here: http://www.carpartsmanual.com/datsuns30/DatsunZIndex/Body240Z/FrontFenderHood/tabid/1750/Default.aspx Quote
MaygZ Posted August 13, 2012 Posted August 13, 2012 It attaches to the body. A small piece of rubber that stops leaves and mud getting out, so causes rust to build up behind it Quote
Scoota G Posted August 13, 2012 Posted August 13, 2012 The splash sheild is attached to the body via three 10mm bolts. Or it will be welded on if the car has been to a panel shop. Quote
MaygZ Posted August 13, 2012 Posted August 13, 2012 My confusion I was thinking of the small rubber bit at the bottom of the steel shield. Quote
PeterAllen Posted August 13, 2012 Author Posted August 13, 2012 Excellent... Thank you. I was confused by the web section near the rear edge of the guard but I guess that just a strengthening rib which maintains the guard profile but doesn't attach to the main body? Quote
Scoota G Posted August 13, 2012 Posted August 13, 2012 That section does attach by two 12mm bolts, one hidden by the door and the other under the gaurd. Quote
