74zzz Posted July 7, 2012 Posted July 7, 2012 I cant find the adjustment slot to loosen my locked rear drum.........how do i losen them? Quote
Linton Posted July 7, 2012 Posted July 7, 2012 take the wheel off there is a hole in the drum(plugged) use a screw driver to rotate off the adjuster, might need to hit around the drum with a soft hammer to break the seal Linton Quote
74zzz Posted July 7, 2012 Author Posted July 7, 2012 ahhh i thought that maybe it idiot! was looking at the backing plate scratching my head........ended up getting the drum off using a rubber mallot and a bit of timber..... i think the cylinder has siezed.......... how readily are they available? Quote
Scoota G Posted July 8, 2012 Posted July 8, 2012 Dimitri will have one or two, recondition doesn't cost that much anyways. My reconditioned set sold for $52.10 on ebay. Quote
