Datsun 240z 280z 260z Brakes All Sold - Thanks to everyone!!!!
Hey everyone, just a heads up on some parts which are for sale in case these particular parts are needed. Make an offer if I only get one offer you will prob get it  not sure what worth but need to go to pay for bigger brakes, the fronts are a great upgrade set and did the job for Targa High Country. Rears I did Targa Tas with as well. Will sell parts seperately.
The front right disc is warped and will have it machined if capable of saving, only $150 for a new one anyway.
*****Turns out the disc is not warped, I had my mechanic check them out today and have a max run out of 3 thou on both. Our brake shudder seems to have come from dodgy wheel spacers, Disc thickness is 22mm which is the same as they are new....plenty of life left*****
Rear Brake drums 260z (finned) within specs with SW Motorsport supplied competition lining on shoes. $50.00 #sold#
Wheel cylinders brand new in Jan 2010)
Brake Master Cylinder (15/16", new in Jan 2010) $20.00 #sold#
Brake Booster  (reconditioned Jan 2010) $70.00 #sold#
Front Brakes for 280z/260z hubs, but can work with 240Z Hubs (hubs not for sale)
Calipers - 4x4 Hilux (12+8) $400.00 for complete set up #SOLD#
- 4 piston with spacers between halves to allow for vented discs
- also machined out to allow for discs
- spaced out from strut mounting to avoid wheel binding
- Discs - DBA919 with new holes drilled for hub mounting and correct PCD
- All machining carried out in a professional machine shop
- Comes with a partly worn set of ferodo ds3000 series pads and a brand new set (already modified to suit, worth about $200 a set)
Will have two sets of lightweight japanese rims with kumho semislicks with enough rubber for a couple of trackdays left for sale soon as well.
They are the ones in the photos on my car now.
****Not sure what happened to the photos, they are correct on my iphone but turn upside down once uploaded****
Brakes now with prices attached!!!
Phone No is 0439301824 if you would like to discuss.
Matt
Dave
I can post, obviously some weight there?
Someone else is chasing these I will let you know tommorow os Monday if they dont want them.
Matt
Dad, Dad,,,, Dave's waving flags and pointing at me again!!!
The Blue Zed up her is making nice little "H" shaped cracks in the drun linings at 231 mm inside diameter!!!
Matt will do a measure up for them, if they are 229.5 mm or under, Im in for them with linings to suit!
