Bigfella Posted December 30, 2011 Posted December 30, 2011 Hey guys I have a 2+2 shell that is in poor condition that I have to get rid of. I am going to cut it up so if any one whats a particular section let me know. If you stake the entire shell you can have it for free. If have to cut bits up we can come to some sort of deal. I have a roof skin of another car that is in good nick. I was going to put it onto that shell. The car has no running gear it is currently siting on a rotisserie. Pm if you interested. If not it will be off to scrap. Cheers Matty O Quote
singhy Posted December 30, 2011 Posted December 30, 2011 hey mate, how bad are the rails?? and also the passenger side dogleg?(the bit behind the the sills) im mainly after the passenger rail but ill change both when i fix em.. and how bad is the floor?? last question, can you post, ill pay extra to cover effort haha thanks Quote
C.A.R. Posted December 30, 2011 Posted December 30, 2011 I'll take the battery tray/inner guard area Matt. I'll call you soon. Quote
Bigfella Posted December 30, 2011 Author Posted December 30, 2011 hey mate, how bad are the rails?? and also the passenger side dogleg?(the bit behind the the sills) im mainly after the passenger rail but ill change both when i fix em.. and how bad is the floor?? last question, can you post, ill pay extra to cover effort haha thanks Hey singly unfortunately the chassis rails aren't worth a chop. and the floors are the worst bits. Not sure about the dogleg. I would rather not post a hunk of metal sorry. Talk soon lurch. Cheers. Matty O Quote
D Healy Posted December 30, 2011 Posted December 30, 2011 HI, Do you have the steering column, do you want to sell it? Dave H Quote
Bigfella Posted December 30, 2011 Author Posted December 30, 2011 HI, Do you have the steering column, do you want to sell it? Dave H Yeah I do might be a bit hard to get to brissy Quote
dattocam Posted December 30, 2011 Posted December 30, 2011 Hi, I may be after the impossible but is the rear 1/4 under the bumper any good? Cheers Cam Quote
Bigfella Posted December 30, 2011 Author Posted December 30, 2011 Hi, I may be after the impossible but is the rear 1/4 under the bumper any good? Cheers Cam Do you mean a particular side or just the rear section. I'm not sur which bit you mean. Quote
Scoota G Posted December 31, 2011 Posted December 31, 2011 How is the area around the fuel door? I need one o them. Quote
Bigfella Posted December 31, 2011 Author Posted December 31, 2011 How is the area around the fuel door? I need one o them. Hey Scoota. The guard with the fuel filler has been welded and patched so it's in ok condition but only a small area around it the filler is original then welded. so depending on how much you needed it may go across the already repaired part. Cheers Matty O Quote
dattocam Posted December 31, 2011 Posted December 31, 2011 Do you mean a particular side or just the rear section. I'm not sur which bit you mean. Sorry I ment the rear RHS. Thanks Quote
Bigfella Posted December 31, 2011 Author Posted December 31, 2011 Sorry I ment the rear RHS. Thanks The RHS guard has a had a lot of work done on it. So it is ok. Are you talking about the back of the car more so than the RHS. I was always going to do a bumper less version So I haven't spent much time on it. I can take a photo if you want. Quote
dattocam Posted December 31, 2011 Posted December 31, 2011 Sorry I meed LHS as well... Basicaly if you take a line from the rear bumper to the rear wheel arch... All of the below section, around to where the bumper mounts are located at the rear. Hope this helps Cam Quote
younggi Posted January 1, 2012 Posted January 1, 2012 hey just out seeing if your shell has the front guards ? if so how much would you like for them thanks Kyle Quote
Scoota G Posted January 1, 2012 Posted January 1, 2012 Hey Scoota. The guard with the fuel filler has been welded and patched so it's in ok condition but only a small area around it the filler is original then welded. so depending on how much you needed it may go across the already repaired part. Cheers Matty O I'll probably just repair mine then, thanks anyways Matt Quote
Bigfella Posted January 1, 2012 Author Posted January 1, 2012 I took a couple of pics today for Cam and Lurch. See for you selves. Not the best condition. I hope this helps. Quote
Bigfella Posted January 1, 2012 Author Posted January 1, 2012 Ohh and sorry Kyle I only have one set of yards I need them for my car Quote
Moderators Zedman240® Posted January 1, 2012 Moderators Posted January 1, 2012 Excuse the hijack, but if you need some guards, I can help... Quote
D Healy Posted January 2, 2012 Posted January 2, 2012 How much you want for the streering column? A courier could deliver it. I will be OS for two weeks from today, but will contact again on my return. Cheers Dave Quote
Bigfella Posted January 2, 2012 Author Posted January 2, 2012 How much you want for the streering column? A courier could deliver it. I will be OS for two weeks from today, but will contact again on my return. Cheers Dave I'd be happy with $40 if you can arrange the courier. Cheers Matt O Quote
dattocam Posted January 2, 2012 Posted January 2, 2012 Hey Bigfella, It seems that my car has rust in the same spot as your shell. Thanks for taking the time for the photo's but I'll have to pass on the 1/4's Cheers Cam Quote
