I have a new set of superpro (purple) urethane bushes I need to fit to my bar, I know how to remove the originals but, how do I fit these one piece units? I dont have a press, would a set of bearing pullers and a large socket be strong enough to push them through?
I was thinking of doing that Benny, but I figured they're in one piece for a reason. New I should of got prothane, but these were cheap at the time  ::) lol
after burning out the original bush , i had to cut out the outer bush sleeve before fitting new bush. they will push in by hand will take some effort they are tight
  • 3 weeks later...
I got these in today with a little bit of work, they were the one piece purple superpro bushes. It's as Datozed says.... I tried pressing in the bushes without removing the outer shells, no chance. I then cut them out and was able to press them, still required a moderate amout of force. They are a really tight fit and should be a big improvement over the original bushes.
