Hey guys n gals
Im building an L28 /auto powered rat rod
I already have the motor and box here, as well as a very nice spare L28
Now it will be an opened bonnet rod
Im looking into the factory style twin SUs set up
Are these hard to get ???
Worth alot ???
Mostly worth the effort ???
Theres a set of Genuie extractors and an electric dizzy goin in
It should wiegh well under a tonne all done
Its a budget build so spending a motsa on triple webers or such,just wont happen
Thanks in advance for any assistance
Welcome, Sounds like a great project you are undertaking.
If you mean the early style twin SUs set up (round tops) they aren't overly rare but they're not common either. Just keep your eyes open. If you mean the flat tops they are as common as grains of sand...ok maybe thats a slight stretch.
Neither are overly expensive, again just key your eyes open and your should find a set for under $100?? Make sure it is a matched pair.
Yes they work very well and are worth the effort. They are not quite as powerfull as DCOEs and not as fuel efficient as EFI but they are a good allround option.
It should wiegh well under a tonne all done you say. Well good luck with that. What do you plan to strip to get the weight down to there? That is quite an optimistic target. Is it to be a race car or road registered? This information would assist us in giving appropriate advice.
i dont think he is using an s30 chassis maybe more like a t bucket or rodster????
Correct
Im using a holden rodeo chassis,with a type of vintage cowl body section,with a stumpy tray on the rear
Like a roadster pick up if you like
Hence where the under a tonne wieght comes in
Itll hopefully be a handfull with the stock L28/auto
Thats for the input regarding the carbs,ill keep the eyes peeled
I have a set of flat tops with the manifolds. You can have them for $15. I recommend you replace the flat tops with the round tops when you find some but at least this would get you going. Its up to you.
