Agno Posted April 8, 2011 Posted April 8, 2011 Hey guys, I'm after a black driver's side door trim for a 260Z 2 seater (I'm not sure is 240 is different?). My current door trims are the ones with the woodgrain inlay. If anyone has a goos condition, non warped black trim with no speaker holes PM, reply here or text me o4o2 595 961. Located in the eastern suburbs of Melbourne EDIT: Also chasing the dimmer switch knob (the one with the light bulb on it that adjusts the dash lights, not the whole thing, just the knob) and a working indicator switch. Quote
Moderators Zedman240® Posted April 8, 2011 Moderators Posted April 8, 2011 Door trim from 240Z is a bit different..also take a note of where your door snib button comes out from; seen 260Z 2 seater trims with holes in different places..just to make it harder! Measure how far yours is from the end of the door to the rod so you can compare to the new one. Quote
Agno Posted May 8, 2011 Author Posted May 8, 2011 BUMP added dimmer switch knob and indicator switch. Quote
Moderators Zedman240® Posted May 8, 2011 Moderators Posted May 8, 2011 Might have a dimmer switch knob....I'll find out tomorrow and with the indicators, you need the whole assembly or just the switch itself? Quote
Agno Posted May 8, 2011 Author Posted May 8, 2011 That would be awesome Dimitri. I really should dig into it a bit further re the indicators, but it's an intermittent problem where the indicators don't work when I want to indicate right. I am after a whole unit so I can swap my old assembly out to see if it is the column assembly or something else in the electrics. Quote
Moderators Zedman240® Posted May 9, 2011 Moderators Posted May 9, 2011 Sounds like it's just the switch itself and not the whole thing... mine works when I give it an extra bit of force when I'm turning right also! I'll check anyway... Quote
