WTB: Engine/Radiator Fan - plastic piece with fins that connects to a metal hub
Hi guys,
I'm in need of a radiator fan piece.
Plastic piece with all the fins. As my current one in the 240z has a bent fin, it does spin, but gets jarred up against the radiator when it reaches the bent fin.
If you're willing to let one go, please reply. I'll reply back shortly.
regards,
Fu
  ;) Hey Fu which fan blade are you after. Have two of them one is shallow dished which retracts fan back from radiator .While the other one is deep dished which projects blades closer to radiator, the blades on this unit have been rounded off on one side. Both are in good shape. Also have a couple of good fan clutch units if your interested. PM me.
        Regards : Alan.    ;D
Fu
I have this one which I used to run on mine, it includes the clutch assy
PM me if interested.
John
:-\ Hey John just out of curiosity is yours from a 260Z or a 240Z. I know the shallow unit one I have is out of a 2+2. While the other one was in a 260Z.
                                                  Regards: Alan.
??? Hey Fu, whats happening. ?!?!?!?!
        Regards : Alan.  :D
                                                  Regards: Alan.
Alan
Mine was out of my 260Z but was running on a L20ET, I doubt there is any difference in application apart from the possibility of a fan shroud that was a welded item on some radiators interfering with it.
John
;) Thanks John.
                                                    Regards : Alan.  :D
Just to close this chapter.
I ended up purchasing John's fan. I needed it fairly urgent.
But now I've hit a bit of snag and require a radiator. It seems the radiator is leaking which causes hot water to hit the fins on the fan which resulted in the fin warping. Warping of the fin ended up jarring the fin into the radiator.
