Guys
Selling on behalf of the new owner of my Sc 240z
Triple 44mm Mikunis c/w Nissan works competition manifold (cast in the US  with independant runners ) , all linkages, 37 mm chokes and 50mm ram tubes
also c/w lower heat shield and rubber isolators (between manifold and carbs to prevent fuel foaming)
Carbs recently refurbished with no wear to linkages or butterflies, accelerator pumps and gaskets (all as new)
Manifold ported to approx 40mm to suit Nismo inlet gasket.
Excellent "bolt on and go" condition ..............recently run on my L26 for comparison testing
These carbs turned 140 rwkw on an L24 engine fitted to the Sc race car ....................the induction noise at 7000 rpm was truly a mechanical symphony
Price $2650
reason for sale .........Group Sc rules unlikely to change to allow the use of triples carbs , owner selling to fund other work to the car
get in quick before they go on ebay
Contact Alan
PM me if you are interested
These are the best carby's you can get IMHO!
For a bolt on proven ready to go set, would make a good buy as they are getting harder and harder to find.
Good luck with the sale.
Hey Alan,
Personally im not interested but would be awesome to see some pictures of the setup... may help with selling them also!!
What size chokes, Jets, Airs, tubes? Every engine will be different so might not be bolt on (well yes will be but for the perfect match for your engine/cam setup some fine tuning might be required) also any spares with that for the $$ ie chokes, Jets, Airs etc.
Question with the Oz Sc rules what are they based on? Oz rules or taken from FIA Appendix K (then appendix J for the year/group of your car). Also see this thread - does anyone know the outcome? 260DET maybe?
http://www.classiczcars.com/forums/showthread.php?t=5611
A zed can get FIA HTP with triples what is CAMS issue - see this car that was for sale a while back it has triples and FIA HTP papers
http://www.racecarsdirect.com/listing/33186/Datsun_240Z_FIAHTP_Race_car.html
