OK so i've got a set of PHH 44s that im rebuilding and i have commited the cardinal sin of removing the throttle shaft from one of them - how screwed am I?
Also what is the best way to clean the carb bodies up? Is the best way to get them looking good just to paint them silver?
If you have a compressor, then try the $15.00 home made soda blaster, Google DIY Soda Blaster.
John
Thanks guys that's great what about the fact I have removed the shaft?
You'll be ok, as long as its not bent.
More importantly,
Can you remember how to put it back together?
And do you have all the parts?
As far as cleaning them up, comes down to what equipment you have access to.
What about carby cleaner and a toothbrush?
I've been pretty careful with it so hoping it wont be bent. I have a service manual and yeah i remember how it goes together and i have another 2 there for reference. It's not really the complicated.
I did another bad thing taking them apart though, i nicked the edges of the throttle plates but i think i can clean them up with sandpaper.
The best thing so for has been Hondabrite degreeser (Honda motorcycle cleaner). Soak over night and everything comes up like new. I ran out though and sounds like getting more will be the next priority. I've been dremelling them with a wire wheel and will probably ended up painting the carbs with silver enamel paint because the cast alloy finish is pretty crappy.
I've ended up with 3 incomplete rebuild kits - mainly the pump gasket stuff so ill reassemble them and order what im missing.
For the record carb cleaner and a tooth brush hasn't been hardcore enough. Carbs have been sitting for around 15 years.
LMAO Your'e gonna burn in Hell Scoota !
So is that the 4th or 5th idea of mine youve liked ?
I like all your ideas so far, i don't think you've had a bad one.
I'm just trying to scam my friend's last bottle, all the bolts that soak in it come up like new. I did the end of my clutch hose and various parts like that which were pretty much black with crap and started corroding.
