stevofoxono Posted December 16, 2010 Posted December 16, 2010 hi all, just got told i need 6new fuel injectors for my 280, got quoted $1030 installed~$120 per injector. are there any alternatives i could buy or is there anywhere in the brisbane area that can do it abit cheeper? cheers Quote
luvemfast Posted December 16, 2010 Posted December 16, 2010 For that price Mega Squirt with RB26 injectors? Mercedes Benz V8 injectors from a wrecker? Quote
Moderators Zedman240® Posted December 16, 2010 Moderators Posted December 16, 2010 I bought 6 new Bosch injectors from EFI Hardware in Mitcham Vic for $99 each a little while ago.. might be good to check price again. Quote
PZG302 Posted December 16, 2010 Posted December 16, 2010 Az new injectors supply new or remanufactured injectors. For the Z the model is AZ135N-6, they are supplied as new injectors, and from memory I bought a set for around $420 from repco, they were on special at the time. They also do performance type injectors as well, maybe worth checking out their website to see if they can do what you need. http://www.aznew.com.au/main.asp?section=Products&subsection=New Injectors and Component Kits Quote
DatPilot Posted December 17, 2010 Posted December 17, 2010 I got a new set of turbo injectors (270cc) from ebay us Was $330 landed Dr Injector Online I think it was called. Quote
stevofoxono Posted December 17, 2010 Author Posted December 17, 2010 http://cgi.ebay.com/ebaymotors/6-Fuel-Injectors-1975-83-Nissan-280Z-810-Maxima-280ZX-_W0QQcmdZViewItemQQhashZitem27b64107a9QQitemZ170561439657QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories Is that what I need? If I did go the turbo injectors would I have to chance the ecu or anything? I've got no savings left so I need the cheapest option possible.. Quote
haul Posted December 17, 2010 Posted December 17, 2010 You can run rb30 injector out of a r31 skyline or vl commodore. Cheers Tony Quote
kolonelklink Posted December 18, 2010 Posted December 18, 2010 why do you need new injectors? will second hand ones do? You can get your old injectors serviced for a fraction of that cost + I have a bout a million used standard injectors at home if that might help you out? Also, never return to that mechanic for anything but dodgey pink slips (if they do them). Changing the injectors is a 30 minute job and the labour cost should reflect that. -pete Quote
