biggels240z Posted September 28, 2010 Posted September 28, 2010 Hey guys i bought a rack which is supposed to be a forestor rack and ment to be a bolt up rack with the use of other tie rod ends has any one else done this and if so do you have any pic? Ive seen other pics but my rack has 6 hydraulic connections which is confussion me !! i bought it frome bay and its meant to be a bolt up mod >?? cheers Richard Quote
KatoKid Posted September 29, 2010 Posted September 29, 2010 Hi Richard. Ive done a fair bit of reaserach on this swap, its far from a bolt in conversion. See my thread for more details http://www.viczcar.com/forum/index.php/topic,7174.0.html Im in not far away in The Basin, PM me if you want some help. Quote
NZeder Posted September 29, 2010 Posted September 29, 2010 Nothing is a bolt up mod when you talking about 240z/260z steering rack replacement. I believe the MX5 units are closer to a bolt up but you still need some cut/welding then the MX5 rack is wider and requires work too. The subie is a better fit from my understanding from a rack length stand point but you still need to cut/weld the stock cross member so that is far from a bolt up. Quote
