BobsYourUncle Posted September 24, 2010 Posted September 24, 2010 As the title says, can you fill the gearbox with oil via the hole for the shifter? I can't get the filler plug undone. I'm sure I've read this before, but I'd like to confirm... Quote
Six_Shooter Posted September 24, 2010 Posted September 24, 2010 No. There is a large plug in the side of the tranny that needs to be removed to fill the tranny. Quote
BobsYourUncle Posted September 25, 2010 Author Posted September 25, 2010 I made a mistake in my first post - meant to say I can't get the filler plug undone. So there's no alternative? Quote
Moderators Zedman240® Posted September 25, 2010 Moderators Posted September 25, 2010 Is the filler plug the square inny or outie? Quote
garvice Posted September 25, 2010 Posted September 25, 2010 I can't get the filler plug undone. Why? How large a lever have you used? Tried a manual rattle gun (spanner and mallet)? Also try loctite freeze-n-release Quote
BobsYourUncle Posted September 25, 2010 Author Posted September 25, 2010 I got it off. I had tried spanner + hammer, in the end I used plenty of penetating oil, braced myself on the front of the car, and pushed with my foot/leg. I googled loctite freeze-n-release, looks pretty nifty - where can you buy it? Haven't seen it at supercheap (not that I've looked I guess). Quote
lightmaster240z Posted September 25, 2010 Posted September 25, 2010 try your local bolt and bearing supplyer they should have it Quote
garvice Posted September 25, 2010 Posted September 25, 2010 Good work, that is a diesel fitters type response. If it doesn't budge, use a bigger hammer. HA.. I get it from my local repco. Has saved me where when I haven't used it I have sheared bolts off. Quote
peter t Posted October 14, 2010 Posted October 14, 2010 You will find that most of these type of bungs are tappered thread so if done up too tight are very hard to undo. A fast hard kick is the best way to break the seal as you have done just don't tighten it up too much when putting it back in as you will have the same problem next time. Quote
