The Clutch on my Engine fan is stuck....
I have a L28 with a 54 Block and N42 head in the Mankini Zed Car.
It now sounds like a hilux when at high revs because the clutch in the engine fan is jammed.
Does anyone know of an easy way to service this component?
I can hook a thermo fan up on a switch quite easily.
cheers scoota, validates my thoughts.
Thermo it is.
Unless you want to keep your zed standard for concourse events, I'd go to a electric fan; gain a few hp just by removing the plastic fan!
far from concourse, already a l28 in a 240z
