Hi guys I'm after a speedo gear to match my new R180 4.1 diff ratio that is going in, I believe it will be Red in color? Can they still be bought new from nissan?
I bought my last purple one (for 4.3) from Trevor at Brighton Nissan...give him a ring with the part #
From memory (mind  you I'm getting older today) was around $30. But get the part number before you call; makes it alot easier and less errors. I think I gave him a list of all the pinion part numbers when I was there...
I'm pretty sure I have the part numbers in a txt file on my home PC..haven't filled the work pc with zed stuff....yet
You guys don't look hard enough: http://www.viczcar.com/forum/index.php/topic,2675.0.html :P
Speedometer Drive cogs:
YELLOW is the 16 tooth for the 3.36  Nissan Pinion Assy P/N: 32702-58S16
BLACK is the 17 tooth for the 3.54    Nissan Pinion Assy P/N: 32702-58S17
BLUE is the 18 tooth for the 3.70      Nissan Pinion Assy P/N: 32702-58S18
WHITE is the 19 tooth for the 3.90    Nissan Pinion Assy P/N: 32702-58S19
RED is the 20 tooth for the 4.11      Nissan Pinion Assy P/N: 32702-58S20
PURPLE is the 21 tooth for the 4.38  Nissan Pinion Assy P/N: 32702-58S21
