Hey all,
Through a series of some stupid thoughts and theories on my own and a mates part, I am in need of an odd part..
Don't know if my explanation will make much sense but I'll give it a crack.  Behind the steering wheel is the small arm that makes contact with the ring on the steering wheel itself to work the horn.  It's held in place by a single screw, holding it to a square-ish piece of plastic.  It has a green wire soldered onto the end of it, right next to the screw.  The arm then reaches out to the left, with a small metal lump on the end, which makes the contact to the wheel itself.  I am in need of that arm, as we kinda ...bent..... the other one  :'( :-[ >:( and it no longer functions properly.  So, if by pure miracle someone has one lieing around I would love to get it off ya!
Cheers,
Scott
fair enough, it is a random part that i'm sure you wouldn't even look twice at, or think about ever  :P
Know anyone wrecking a Z?
Haha I know exactly what you are talking about and I need one too! Think I might just bend up a piece of metal though, nothing too complicated..
Broke in half somehow and now it's not long enough to bend up and make contact. Just hoping a cop doesn't pull me over and ask me to test the horn (it's happened before)
I know the part.  I busted mine when I had the steering linkage disconnected and was spraying the car.  Had a plastic bag over the wheel to protect it from the over spray, but the wheel got turned a few times and the plastic bag wrapped around and eventually snapped it.
Dad and I fabricated a new holder out of some plastic bits and pieces that we had around the place.  Cannot remember exactly what it was that we used though.  May have been a cable saddle (used to hold electric cables in place when wiring a house, etc) or a plastic automotive cable connector (with the metal parts removed.
I'll see if I can get a picture of it for you.
Cheers,
Matt
sounds like a fairly popular part to get broken  ???  any chance that in internals of the steering collum would be the same amongst other datsuns? need to hunt down a part for rego- lousy rego- if not, maybe might have to fab something up
