Hi all,
Still looking for;
1) luggage tie down straps for rear parcel shelf
2) round caps that fit onto the round seat adjuster knobs to hide the nut and bolt hidden beneath.
3) stainless trim the surrounds each of the rear taillights (that fixes onto the rear fascia panel)
4) little metal clips that are welded to the rear of the car directly beneath the rear tail light cut outs. These are used to hold the base of the rear fascia panel onto the car.
Adam
You can get the luggage straps from here
http://www.zeddsaver.com/luggage_straps.html
or
http://www.zcarsource.com/content/p/9/catid/7840_8383/Luggage_Straps_70_78
or
http://www.datsunzparts.com/trim.htm
and then there is evilbay they turn up every now and then.
Also found another early-ish zed here in NZ that was missing the luggage straps so maybe they were an option on the early cars and standard later? Only if there was more info on that :(
