chris240 Posted September 3, 2009 Posted September 3, 2009 fellas, whilst browsing at a local wrecking yard this arvo, I spotted a side damaged 1986 z32 300zx V6 turbo sitting nicely in the yard...are any parts backward compatible with 240 & 260's.....discs, calipers, gearbox perhaps ?...even the motor caught my eye Quote
C.A.R. Posted September 3, 2009 Posted September 3, 2009 Check to see if the diff is a long nose R200... Quote
Surly_Z Posted September 3, 2009 Posted September 3, 2009 Ive seen a vg30e conversion into a 240z by a guy in the states, i think his name was BLOZUP or something. I used to own a z31, but i found the engine wasless "torquey" than the l28 ive got in my 240z. If its manual, the gearboxes are pretty strong. Im sure you can do a brake conversion too. Quote
Scando Posted September 5, 2009 Posted September 5, 2009 As Lurch mentioned, check the diff. You might pick yourself up a very cheap R200 LSD! Quote
