  • Replies 65
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
I was speaking in laymans terms, Zeddophile.
Jeff: It's 0.9mm mild steel sheet with a zinc coating on one side ;)
Today I was busy working on the back of Joel's Bus... :-\
There were a lot of bog & rust holes in the 'slam panel' where the hatch locks into, & since you can get new panels easily I decided to unpick it & see what the panel(s) was like underneath - I'm glad I did! :o
Damn, i hope mines not that bad.. i need to stop ignoring my slam panel, its starting to look ugly :'(
  • 3 weeks later...
Got some more done this past Weekend.
The Slam panel will be fitted hopefully this WE, which will finish off the rear of the Zed.
The rear sill cover panel on the drivers side is looking rather ordinary
though. It's clearly been bogged over, so I'm not looking forward to finding out what it's like underneath :-\
Also the lowered King springs have arrived & will be fitted after the bodywork is complete.
  • 2 weeks later...
Geez im glad i didnt let it go for another year. Would have gone to drive out of the garage one day and the Zed would have split into two!! :o
Anyway my wifes working on the nursery today for our baby due in Feb. and im cleaning out the garage for my other baby when ever she's ready :D
  • 2 weeks later...
  • 4 weeks later...
I moved back around the the PS sill dogleg & did the same as the DS (similar amount of rust + inner sill panel damage ??? ) - lot of work though.
I also repaired the DS rear wheelarch (which I was deading to do) as a previous repair was rather poor...
I am stocked at how it cam out! It followes the factory lines now!!!
I rolled/folded up a new section & but welded it in.
If you can be more specific in your question, I can give you a more detailed answer :) ;)
I use a 4" grinder with a 1mm cutoff disc for larger sections, but for less than 100mm wide stuff I use my little Gillotine ;)
And yes to your 2nd question. If I have to make it smooooooooth I sand it down with a 40grit sanding disc. (BTW, NEVER use a sanding flap wheel on bodywork!!!).
I'd like to know why as well. I find they smooth down welds very well and hold together for quite a while. What do they do to thin panels that you don't like?
If you are not carful they can warp your panel from the heat.
How ever i have been using them and my and have had no issue with them.
but then again i use a solid grinding disk to knock down the majority of the weld  and use the flap disk just to tidy it up
Flap wheels are actually convex (& become more-so through use) and have a tendency to follow imperfections. While they do a good job on most surfaces, if you are sanding down a weld on panel, you may find (I know I do) that you can develop ripples along the welded section.
A sanding disc with a rubber backed pad does not do this & the fact that sanding discs are cheaper than flap wheels is a bonus ;)
