reverendzed Posted May 20, 2009 Posted May 20, 2009 hey guys...I know there are a few zeds out there that are parts cars at the moment so here goes! I need the hard line and rubber hose that goes from the clutch master cylinder to the slave cylinder, this is for my manual conversion any help would be appreciated. regards, Rev. Quote
Moderators Zedman240® Posted May 20, 2009 Moderators Posted May 20, 2009 Dave, easiest thing to do is grab some mig welding wire, make a copy of all the bends of an original one, then go to a brake place and they can make you one. It will save you days of searching. They could make the flexible one also, even make it a braided steel one while you are at it! Just make sure you take an example so they install the correct ends. I was about to do the same thing but sold the 2+2.. Hope it helps Quote
RB30X Posted May 21, 2009 Posted May 21, 2009 Hi Rev, I could pinch one off my 280zx but those fittings are so old, even with a split ring spanner they just strip the nut. Better off talking to the hose doctor or something. Still if you want i can have a look at removing it. cheers Quote
C.A.R. Posted May 21, 2009 Posted May 21, 2009 Easier to get a new one made up by someone like ABS Brakes. Quote
