1973 240z gearbox synchro rings
gvowzcar
Hi all, new to this site, I am after a set of synchro rings for from research I think is a FS5W71B gearbox (maybe FS5C71B) (1973 240z)
Happy with Bronze rings. ?? are they available in Aus and if yes where.
Found a US site but unsure if they would be suitable for AUS box or are they all the same. Really only need to fix the standard 2nd gear issue but figure might as well replace the all while I am there.
Thanks Graham
Link to comment
Share on other sites
Welcome Graham.
Firstly you actually need to determine what gearbox it actually is.
Unless you know the full history of the Z, it could have any Datsun 5 speed fitted as they are now over 50 years old.
Both brass synchro rings (about $100ea) and steel bulk rings (well over $200ea!) and are still available new from Nissan.
If you are not inclined to do the rebuild yourself, I'd send the gearbox to either:
Les Collins Racing in Vic: https://lescollinsracing.com/contact
Or
Stewart Wil
kins Motorsport in NSW: https://www.swmotorsport.com.au/
HTH
Edited by C.A.R.
Link to comment
Thanks for response, will try nissan for synchros, I assume that they will fit regardless of which box I have (think its original although probably rebuilt at some stage), Have not tried to get any z parts from nissan, I thought they would laugh at me if I tried to order zparts from them. Will rebuild the box myself, Did my apprenticeship with a datsun dealer starting in 1973, was always surprised back then that most of the 260z coming into australia then were 2+2s.
Link to comment
No they will not.
Either type of synchro has their own hub assembly, so they can't be interchanged.
You need to remove the cases to determine what synchro / bulk ring box you have and order accordingly.
Furthermore, if 2nd gear ring is 'crunching' the others won't be far behind it...
Edited by C.A.R.
Link to comment
