mossy Posted February 21, 2009 Share Posted February 21, 2009 I'm trying to replace the handbrake cable on my 240z without having to remove the diff but I can't seem to get the two tabs out that slide and lock the cables in position at the front of the diff, anyone got any tricky ideas? Quote Link to comment Share on other sites More sharing options...
dazzed Posted February 21, 2009 Share Posted February 21, 2009 is the car on a hoist? if you are only changing the inner cable leave the outer on the car, 35 years of clips wedged in ,they dont come out easy makes it even harder when you cant get to them, clean them with wd40 blow them off with compressed air a few times wriggle them around a bit bit more wd40 a silent prayer for patience bit more compressed air and wd40, then get one of those old stanley square drive blue handled screw drivers and twist and lever them out, but remember you have to get them back in , Quote Link to comment Share on other sites More sharing options...
silverz Posted February 22, 2009 Share Posted February 22, 2009 Hi Mossy, I hope you are getting it sorted. Where did you get the new handbrke cable from? regards Peter Quote Link to comment Share on other sites More sharing options...
Mr240z Posted February 22, 2009 Share Posted February 22, 2009 Hi Mossy, I hope you are getting it sorted. Where did you get the new handbrke cable from? regards Peter And how much did it cost. Thanks Quote Link to comment Share on other sites More sharing options...
mossy Posted February 22, 2009 Author Share Posted February 22, 2009 After a heap of WD40 an hour of twisting the clips side to side and some colourful language I got the cable out and the other one in, but i can honestly say i never want to do that again I used the cable from my v8z since its not on the road yet but there is a guy locally who makes handbrake cables so I'm going to take the broken one there an he needs parts off the old one to rebuild it, i think its about $140. Quote Link to comment Share on other sites More sharing options...
silverz Posted April 15, 2009 Share Posted April 15, 2009 Hi, I spent a long day doing maintenance on the 240z, am in the middle of replacing the rear wheel bearings, sourced them locally just need to press the old outer bearing off and the new one on. Also replacing the rear wheel cylinders, clutch slave cylinder and have taken the handbrake cable off to free it up so it will disengage properly. We have freed the cable up as best we can and had to cut some of the broken plastic coating off the inner cable where it was jamming. The outer cable is also broken at one end. we will try to fix it tomorrow by clamping it on the metal end piece with a small hose clamp. I think it will come out okay, but longer term I need a new cable. My question is does anyone know where to source a new handbrake cable? And Mossy, how did you get on getting one made up? Thanks, any advice would be great. Regards Peter Quote Link to comment Share on other sites More sharing options...
mossy Posted April 15, 2009 Author Share Posted April 15, 2009 I didn't actually have one made up, I just used the cable from my other Z. I'll eventually have to get one made though but here is the website if your interested. http://www.autocables.com.au/default.asp Quote Link to comment Share on other sites More sharing options...
silverz Posted April 15, 2009 Share Posted April 15, 2009 Thanks Mossy, I will get mine back on for now (if I can what a job getting it off!) and will look into the replacement later. Please let me know if you get these guys to make your new one so I know how it goes. Thanks Regards Peter Quote Link to comment Share on other sites More sharing options...
