Hey guys,
Selling some of my old gear - this is an RB conversion for a Z,
They are Castlemaine Rod Shop mounts with reasonable engine mounts, offset gearbox crossmember and balanced tailshaft, all you need is a rear sump and your away!
This gearbox crossmember uses the original Z engine mounts - 260z (won't work with the 240z!!!) and won't work with the bigger RB25 gearbox as it is a fat sucka! Will work with the RB20DET & RB30 N/A gearbox!
After $420 for the lot!
I will also throw in these other engine mounts I whipped up so I could use a bolt/bush style mount - however, you will need to modify your crossmember to use these engine mounts!
I can be contacted on - 0403 836 526 or tonycharger72@hotmail.com
To much $$$ :-)?
Open to offers fella's, this stuff is just taking up space and it would be good to make someone's life easier swapping an RB into the car instead of sitting in a box in my garage :-)!
Yes probably, had an offer on the mounts - but you sure this will suit your application mate?
I have the exact same CRS kit sitting will all the other crap (read: infrastructure) I've accumulated and having a tailshaft would be handy.  Saves having to get a spline and someone to make one up.
I think he means .... looking at your signature you have a 2+2 and this shaft will be for a 2 seater = too short = mods = just do your own for the $$
Thankyou Mike, sorry, I should have made myself clearer!
This tailshaft is from a coupe, will not just bolt into a 2+2, not long enough!
I am in Canberra!
Snap! I didn't see that, thanks for pointing it out  ;D
