RestoZ Posted August 5, 2022 Posted August 5, 2022 Hi guys Need help identifying where the attached washers/seals/spacers/? go. For some reason I had these bundled separately to all my other grouped bits and I just can't remember where they came from (old timers disease, I think). They are a firm rubber, but they are pliable. Outside diameter is 40mm, inside 17mm and 23mm across the raised sections. Car is a 77 2+2, commonly referred to as the Bus by Locky. Any suggestions really appreciated. It's driving me nuts. Cheers Paul Quote
Linton Posted August 5, 2022 Posted August 5, 2022 gear box cross member between outer bush and chassis, main bolt Quote
RestoZ Posted August 6, 2022 Author Posted August 6, 2022 2 hours ago, Linton said: gear box cross member between outer bush and chassis, main bolt Thanks Linton, my sanity has been restored, although some who know me may disagree! Your knowledge is invaluable. This is the final missing piece to the puzzle, so can move forward now. Thanks again. Cheers Paul Quote
