Hi all,
as some of you know, I recently had my auto Z converted to 5 speed, with some hiccups along the way.
One problem being the stick sitting too far forward and fouling on the console.
But, with Thomas (nuclear_z) to the rescue, that problem is solved. A big thanks to Thommo  ;D
Can someone show me how the leather boot is usually attached to the console. Is it with clips/bracket? 2 sided tape?
I am thinking of the momo boot that will attach to the bottom of the momo knob I have or should I go for oem one that might come with fitting hardware?
cheers, Mike
Hey Mike,
When I did my conversion I bought a leather shift boot off ebay and I'm quite pleased with how it looks. It's a remake of the original 260z one apparently. I used clips to attach it to the bottom of the centre console but they were given to me by my mechanic so I can't tell you where I got them.
Check the thread below to see how it looks:
http://www.viczcar.com/forum/index.php/topic,2768.15.html
Thanks Stevo, looks great! I think I'll try Warren at AllZparts first for the boot but they'll prob be on holidays  :(
Failing that I guess i'll try ebay from the states.
Hi Mike!
Hope the gear stick is still connected  :P
If you are looking for clips to hold the boot on, try trim clips that hold on dressings to external seams on cars... The ones from mini seams on should work a treat.  8)
Let me know if you want some because I will pick them up and send them on for you.
Cheers,
Thomas
Hi Thomas,
I picked up a momo leather boot and sourced some clips from my mass of 120Y bits I have at home. Trial fitted looks great.
Just have to wait to get the inner rubber boot before I put everything back together. Am going to try AllZparts tomorrow or if they don't have one, ebay.
Also considering a stereo at this stage since the console is out.
Gearstick has not come off at this stage! ;D
Rang mike about that boot already (no good for what he wants)
If anyone wants this gearstick boot, the seller is up the top of my street
I can pick it up and ship to you .Let me know
                                                            Paul
Mike,
Can you please take a photo of your boot and send it to me. I will need to get a boot for my console soon and have not seen anything I like.
Cheers,
Thomas
  • 2 months later...
I bought a cheapo from Supercheap. It looks good and to fit it, i took off the metal bar that holds the original down (4 screws, 1 is hard to get too so i took one of the electrical switches out (Clips in) and put the screwdriver through there.) Then i made a small hole around the boot, screwed it back on and applied a tiny bit of super glue to the top of the boot near the gear knob. Watch out though, i did it too high up and when i shifted to 5th, the boot came unstuck, no hassle though. Looks great and was only 10$ from supercheap.
