Apart from shortening the length of the shifter, I don't believe there are any short shift kits available.
If it was a 71c box, it'd be a different story...
so i would have to cut the length down and re tap a new thread for the gear knob? how do i tell which box i have? is it on the box itself? i looked at a web page that has what box each model has.. though the issue is that mine was a manual conversion.. so im not entirely sure what box it has.
Yes, that's correct.
It's most likely you have a early Zed box anyway.
A true "short shifter" changes the pivot angle needed to change gears.
Cutting the shifter length just gives you a shorter length shifter with the same shift length.
Does anyone have a true "short shifter" in there Z?
My zed has a very short stick (see gallery) with the standard box.  I have found I actually have to slow down the shift action simply because the box can't keep up.
Dad's Super7 has an even shorter stick but you can slam it between cogs no problems, all in the box design.
Dale
yeah ultra short and notchy.  ;D
using r32 box with S14 short shift kit and pivot block changed to s14 maybe 15mm movement to engage to a gear very very short.(s14 stick is 25mm further back, helps the clearance on the tunnel and positions the stick closer to original spot) .
bit notchy and like above post sometimes have to change slowly for gearbox to catch up, but can slamm through the gears  :P (feel sorry for the gbox though)
