Al_240Zee Posted May 9, 2022 Posted May 9, 2022 After trying to source springs and struts in Aus, ended up buying the Eibach springs and adjustable Koni's and some other bits from the US. Would be keen to hear thoughts on how they perform if anyone here's tried this combo. Quote
theremm Posted May 9, 2022 Posted May 9, 2022 Haven't used them but also considered purchasing this combination - would be keen to hear your thoughts once you have installed? Quote
Al_240Zee Posted May 9, 2022 Author Posted May 9, 2022 28 minutes ago, theremm said: Haven't used them but also considered purchasing this combination - would be keen to hear your thoughts once you have installed? Sure thing, but still a fair way off. Body shell about to be painted, then hoping to get it on wheels, but would be closer to end of year or early next before I get the engine / gearbox etc, and get it running. Quote
C.A.R. Posted May 9, 2022 Posted May 9, 2022 The springs rates are very soft - Les Collins tested a set and they come in at around 180lbs/in / 3.5kg/mm ! Typical squishy/soft ride to suit the Seppos... Also, if those are the Koni's that the ZStore had made for them, they are a full length damper and WILL NOT work with a lowered Z. If you are keeping your Z at factory ride height, you wont have a problem. Quote
Al_240Zee Posted May 10, 2022 Author Posted May 10, 2022 20 hours ago, C.A.R. said: The springs rates are very soft - Les Collins tested a set and they come in at around 180lbs/in / 3.5kg/mm ! Typical squishy/soft ride to suit the Seppos... Also, if those are the Koni's that the ZStore had made for them, they are a full length damper and WILL NOT work with a lowered Z. If you are keeping your Z at factory ride height, you wont have a problem. Did he test the linear ones or the progressive springs? These are the Koni's https://www.thezstore.com/page/TZS/PROD/classic20b04/23-1032 Don't mind standard ride height. Don't want squishy ride. Quote
C.A.R. Posted May 10, 2022 Posted May 10, 2022 1 hour ago, Al_240Zee said: Did he test the linear ones or the progressive springs? No idea. And I didn't know there were two different types. Quote
