Clarky93 Posted February 5, 2022 Posted February 5, 2022 hey guys, i thought i would post my l28et build makes 450hp/720nm i think the head ran out of flow we try adding more boost it didnt do anything. The tuner said the rear housing is 2 small ".83"or the head won't flow no more l28 block F54 stock l28 crank, spool rods. bored out to 88.5mm with kameari forged pistons , kameari damper p90 head 2mm mls headgasket the head been shaved two or 3 times head is pretty stock apart from a very small port and polish, cooling mod and heavy duty valve springs kelford 225lb the cam is a stock cam been grind to a sports cam has all the new efi stuff haltech 750, cas, ls1 coils, 1000cc injectors e85, g30-900 im looking at maybe porting the head abit more and installing a cam to see if it can hit the 500 hp any advice would be appreciate gav240z and sexual_sushi 1 1 Quote
Administrators gav240z Posted February 8, 2022 Administrators Posted February 8, 2022 Interested in your CAS set up and more detailed photos of your engine bay. 450hp is a respectable result - given the work done so far. Quote
Administrators gav240z Posted February 8, 2022 Administrators Posted February 8, 2022 Thanks, I was looking at those as an option to control ignition but retain my Triples. Quote
