trev Posted August 7, 2021 Share Posted August 7, 2021 i am pretty sure mine has died broken plastci bearing retainer and stator off centre, found ball bearing loose and magnetised to side of stator! can this be repaired? if not i am hoping to buy one in good running order let me know thanks Quote Link to comment Share on other sites More sharing options...
trev Posted August 8, 2021 Author Share Posted August 8, 2021 hey guys update to this, i found i had a spare dizzy, fitted it and have the exact same problem... misfiring on no2 also tried diff cap and rotor, and even tested and swapped lead to no2 with no change but with the timing light i get signal through 1, 3,4,5,6, just nothing on2! any ideas? Quote Link to comment Share on other sites More sharing options...
peter t Posted August 8, 2021 Share Posted August 8, 2021 123 dizzy. Quote Link to comment Share on other sites More sharing options...
trev Posted August 8, 2021 Author Share Posted August 8, 2021 you mean 123ignition?? Quote Link to comment Share on other sites More sharing options...
C.A.R. Posted August 8, 2021 Share Posted August 8, 2021 27 minutes ago, trev said: you mean 123ignition?? Dont! I'm not sure Trev. I'll have a think and text you if I come up with anything Quote Link to comment Share on other sites More sharing options...
trev Posted August 8, 2021 Author Share Posted August 8, 2021 thanks dude.... its got me stumped unless i just lucked out and both dizzys have the same prob. but i guess if they both have the same issue, its further back? the coil is almost brand new though (GT40) but def the first one has collapsed. i pulled it apart a bit more and the half circle of plastic retainer and ball came out. so now basically the stator jams the rotor i still have an old points dizzy... but no resistor type coil. how much of a danger would it be to run the points dizzy without resistor? or run the resistor with the GT40? Quote Link to comment Share on other sites More sharing options...
C.A.R. Posted August 8, 2021 Share Posted August 8, 2021 You'll burn the points out if you do that. Quote Link to comment Share on other sites More sharing options...
trev Posted August 9, 2021 Author Share Posted August 9, 2021 hey everyone well going to put my hand up for being a bit daft after all that it appears if a plug has failed you dont get to signal down a lead... i assume because it has no ground? in any case problem solved.. car is back running on all 6! lesson learned... and maybe valuable for someone else BTW the plug "looks" fine... i guess they can be deceiving. in the bin it goes! thanks god for a bank of spares! Quote Link to comment Share on other sites More sharing options...
