Hi Folks,
Just looking for spare parts.
If you have any old/broken/aborted projects let me know?
Thanks,
Gavin.
  • 1 month later...
Gav,
Going through the same exercise.
Have just got antenna all apart all that remains is to:
- use the trimmer line to replace my broken plastic reel;
- replace (if possible) the broken rubber's on top (possible via rubber parts site) and decide whether the 'fingered' washer/nut needs replacing (as only has 3/4 of the fingers).
 Interested if there is any excess of parts.
Huw
No spares I'm afraid, but I was considering purchasing this..
https://www.ebay.com/itm/DATSUN-240Z-Harada-Power-Antenna-Genuine-OEM-260Z-280Z/203038904381?hash=item2f460fd03d:g:2PUAAOSwmyle9lSG
Go halves?
I'm still persisting with trying to take mine apart carefully. Really don't want to break anything unnecessarily.
  • 4 months later...
Revisited this recently with the line trimmer.   Will see how it works.
still need to service the motor and. Heck gears.
antenna mast was a pain. The brass connector that joins the final metal road and the plastic extender coil is a tight fit and wouldn’t go back in.   Had to clean and lightly sand to get back in.
I will be buying the rubber bits from 240zrubber parts.
H
Nice, let me know how you go! I forgot about this project. I got stuck on separating the mast pieces and was afraid I'd break the antenna tip off!
  • 1 month later...
Not sure what year your antenna is - but mine was a 'pointy tip' one.  The antenna tip actually screwed off (which saved me from breaking it but meant that I was paranoid about it 'disappearing' in the shed (despite being labelled and in a zip lock!).  This then lets you slip the final piece of the mast out.
The upper sections of the mast were a pain in the neck as they are fragile but I don't appear to have destroyed it.
Would be interested if you know of any source for the 'finger washer' as mine is unwell (useable...barely).   Correct me if I am wrong but does it function to improve the ground for the mast?
Shortly to do a rubber part order to finish this job and will then turn to the original radio.  Although, I am in two minds - if I recall right it still has the original chalk marks - so I don't want to clean them off - but I do want to make sure it works.
H
I need to get back to this project. I kind of shelved it when I got a job and I didn't want to break it forcing anything apart.
