DreamZproject Posted October 10, 2019 Posted October 10, 2019 Hey guys, I have an aftermarket alu radiator and I'm a bit nervous about not having an overflow bottle on it... can anyone recommend a decent small alu/ stainless one so I can more easily monitor my coolant levels? Quote
DreamZproject Posted October 11, 2019 Author Posted October 11, 2019 I like the look of this unit, but I dont understand how it overflows if it gets too full... it seems like a sealed unit... https://www.mishimoto.com.au/aluminium-coolant-reservoir-tank.html?utm_source=facebookAU&utm_campaign=DPA&gclid=Cj0KCQjwrfvsBRD7ARIsAKuDvMMfebdw4Yq142ODPeXLS0jsyTMfrukYWQQ_2GBIaW2rvr8wXjnKj_EaAiREEALw_wcB Quote
C.A.R. Posted October 11, 2019 Posted October 11, 2019 I wouldn't bother Robbie. Just use a non-return rad cap, and check the coolant level before you drive it. Quote
DreamZproject Posted October 16, 2019 Author Posted October 16, 2019 How often would you suggest it gets checked. I drive the car a pretty decent amount, ie. Twice a week on average and sometimes it's for running around so I dont always have the opportunity to check... Quote
C.A.R. Posted October 16, 2019 Posted October 16, 2019 Just check it before you drive it - it's not difficult. Is it using water? Quote
DreamZproject Posted October 17, 2019 Author Posted October 17, 2019 The fan ticks on fairly regularly in warmer weather and it's not on the highway... I guess I'm just not used to having to pop the bonnet every time I use it... Quote
Roady Posted October 17, 2019 Posted October 17, 2019 If it’s overheating, or using water then that’s an issue. If it’s not doing either of these things, as Locky said, perhaps check it a couple of times to make sure it’s not losing water then you’d probably be right just to drive it without checking every day. Quote
