i have a 260 gearbox which is being used only for parts..
i'll have a look and see if I can figure out what your after.
No thats not it !
its the telfon/plastic bush under the gearbox selector or gear stick its a cylinder type that accepts the ball on the end of the gear stick , the new one i ve got is very loose and i m changing the gearbox over and want to elminate any slop that might be there!!!
cheers
Richard
yeah that sounds like it ! i was hoping somewhere in australia could supply it!!!
Have you tried your local Nissan dealership?
