Hi there i'm chasing any R200 diff that is 3.7 ratio or higher. QLD preferred but if you are willing to ship that would be even better. If i could have my way an open 4.11 would be the best.
Posted (edited)
I have a long nose that was built for the abandoned project so all new bearings and seals. It has a Nissan torsen LSD centre which would require axles to suit and a finned cover so not a cheap setup. The case has a splash oil feed line to the front bearings , very schmick. It's a 3.7, good luck finding a 3.9 or 4.1 although they are available used ex Japan, at a price. I'm at Warwick, 4370.
Edited by 260DET
So it's an S15 shortnose centre in a longnose casing? As it can't take the zed stub axles it's not what I'm after sorry, I need a bolt in solution.
