Gtv240z Posted March 9, 2019 Posted March 9, 2019 Does anyone know how much advance adjustment you get out of the kameari and tepp brand camshaft sprockets? Quote
Gadget007a Posted March 19, 2019 Posted March 19, 2019 (edited) I have one at home I will measure it up and let you know tonight. Just measured mine up and it appears to be able to go more than one tooth each way and from measuring the sprocket it is about +- 10 degrees rotation of the cam so in term of crankshaft I guess it would be double that Here is the instruction sheet that comes with it if you can read Japanese. Edited March 19, 2019 by Gadget007a Added detail Gtv240z 1 Quote
Gtv240z Posted March 19, 2019 Author Posted March 19, 2019 Fantastic, thanks for the info! I see you are in Adelaide also do you get out and about in your zed much? Thanks Craig Quote
Gtv240z Posted March 19, 2019 Author Posted March 19, 2019 Translated poorly via a phone ap: Sliding cam sprocket gear ・ ・ Please start the minp. ・ First assembled at this position, then parv tie ・ It is normal when the center line is aligned. 1 · Position of associate 0 0 I will do my best 1 item TEL 8-998-2323FX04891702 Kameari Industrial Co., Ltd. Released by: Sakitama Prefecture Yashio City Yoricho 3-1-16 2. Advance Baltai ・ Amber cam advances 1 memory in the direction of rotation of the engine 'I'm in a state. 1 memory advances 2 degrees in cam angle and 4 degrees in crank angle. 3. Delay Paltai 11 to 19 (N · m) 1.7 to t. 9 (k th) [Screw bolt tightening torque] ・ Be sure to tighten correctly with a torque wrench. Please. 4. Tighten the slide bolt 1 memory is delayed by 2 degrees in cam angle and 4 degrees in crank angle. Being in ・ The cam pile is delayed by 1 memory in the reverse rotation direction of the engine Quote
Gadget007a Posted March 19, 2019 Posted March 19, 2019 12 hours ago, Gtv240z said: Fantastic, thanks for the info! I see you are in Adelaide also do you get out and about in your zed much? Thanks Craig The Zed is off the road, am collecting parts to give it a freshen up / resto Quote
