Administrators gav240z Posted March 9, 2018 Administrators Posted March 9, 2018 As shown in this photo. I need the RH side however that goes on the right SU carb (not the carb 1 with the vacuum advance port on it) - mine is missing (also the fastener and washer if possible?) Quote
1600dave Posted March 9, 2018 Posted March 9, 2018 If I forget (ie don't reply by tomorrow night), remind me ! I have a set of zed SU's in the shed, not sure exactly what type or even if the bracket is still on them, but if it is I could part with it. Won't be able to look till tomorrow arvo. gav240z 1 Quote
Administrators gav240z Posted March 9, 2018 Author Administrators Posted March 9, 2018 Will do, I just noticed it was missing so obviously someone had a tinker with mine before and forgot to put it back on. Quote
1600dave Posted March 10, 2018 Posted March 10, 2018 (edited) I think you're in luck, is this what you're after ? That's the correct side ? If so, send me your address and I'll post it down. I'll probably never use the carbs, even if I do it probably won't be on a zed so I can make do without the fancy zed locking brackets if neccessary. Edited March 10, 2018 by 1600dave gav240z 1 Quote
Administrators gav240z Posted March 10, 2018 Author Administrators Posted March 10, 2018 That's what I need! Will send PM. Quote
