GregTas Posted October 12, 2017 Posted October 12, 2017 (edited) Hi, I'm after a castle nut that goes on the front stub axle. Is there somehwere in Aus I can get one from? I did a bit of a search on the web but didn't find anything. Greg Edited October 12, 2017 by GregTas Quote
PeterAllen Posted October 12, 2017 Posted October 12, 2017 Have you tried; Powers Fasteners Coventry Fasteners Nut & bolts Tasmania. If they don't have a 'castellated nut' you can fit two blades to a hacksaw and cut your own slots or, if you have a steady hand, use a cut-off disc in an angle grinder. Quote
260DET Posted October 12, 2017 Posted October 12, 2017 Early Commodore stub axle nut fitted my Z31. Quote
GregTas Posted October 14, 2017 Author Posted October 14, 2017 I did try my local nut and bolt shops with no joy which is why I asked here. The nut is 18mm x 1 so not a standard metric size. Thanks Richard on the Comm nut I'll look into that. They should be a bit easier to find if they fit the S30. Quote
