240ZR Posted December 2, 2016 Posted December 2, 2016 After the following if anyone can help; LH door frame for 260Z 2 seater (the chrome/stainless one that takes the rubber across the top) A good T-bar shifter handle (plastic bit only, not the whole assembly) Original battery clamp Let me know whats available. Thanx in advance. Quote
240ZR Posted December 2, 2016 Author Posted December 2, 2016 Also, where can I buy new rubbers for these?? Quote
AndBir Posted December 2, 2016 Posted December 2, 2016 Also, where can I buy new rubbers for these?? Cannot vouch for the quality : http://www.ebay.com.au/itm/DOOR-GLASS-RUN-CHANNEL-PAIR-2-Pcs-NEW-FIT-NISSAN-DATSUN-510-240Z-1200-B110-B210-/282277044583?hash=item41b905e167:g:xG0AAOSwiONYQRSL Quote
240ZR Posted December 2, 2016 Author Posted December 2, 2016 Cannot vouch for the quality : http://www.ebay.com.au/itm/DOOR-GLASS-RUN-CHANNEL-PAIR-2-Pcs-NEW-FIT-NISSAN-DATSUN-510-240Z-1200-B110-B210-/282277044583?hash=item41b905e167:g:xG0AAOSwiONYQRSL Nah, they're not the ones I'm after. These are the bailey channel rubbers which guide & seal the door glass. I'm after the rubber that runs across the top of the chrome door frame which seals it against the roof gutter rails & down the windscreen pillar. The 240's never had these, only the 260's. I don't mind if they're 2+2 as they can be cut down. If you enlarge the pic above you'll see what I mean. Quote
AndBir Posted December 2, 2016 Posted December 2, 2016 Also, where can I buy new rubbers for these?? http://www.rarespares.net.au/rarespares/ProductPage.aspx?product=RDS4016 http://www.vintagerubber.com/datsun260z-DriverDoorGlassSeal.aspx Quote
