Hey guys ,
Will a 16 x7 +25 offset fit my z??
Im looking at a cheap set for a rolling shell
It has coil overs and brake upgrade not too fussed about the fit as long as they go on!
Hey guys ,
I have run 205/50's on 16x7 +20 on my 240 with about 4mm clearance to the spring perch on the standard struts. Pending tyre size, I would expect a +25 16x7 to clear the strut if you are running coil overs with a smaller diameter lower Spring perch.
