KatoKid Posted July 21, 2016 Posted July 21, 2016 Well my faithful rotisserie has served its purpose and is no longer required so time to move it on. Comes with everything you need to fit your 240/260Z, well balanced and easy to use and roll around. Was borrowed by another member (Jamo) and had a 260 with full interior, doors, glass etc still fitted so no question its strong enough! $400 Pick up eastern suburbs. David. Quote
aircobra Posted July 21, 2016 Posted July 21, 2016 interested, couple of questions looks like the rear pickups bolt up to the bumper bar brackets. what happens in the front? goes under the engine rails? Quote
aircobra Posted July 21, 2016 Posted July 21, 2016 one more - when the car is attached, what the ceiling height required to turn the car over and at the lowest point. just want to be sure i can wheel it out of the garage and turn it over Quote
KatoKid Posted July 21, 2016 Author Posted July 21, 2016 Yep to the first two questions. Will measure the pivot height and get back to you. Quote
KatoKid Posted July 22, 2016 Author Posted July 22, 2016 Aircobra: Centre of the pivot point is 1100mm off the ground so measure the total width of the car, divide by 2 and add this to 1100 to give you max height when its on its side. Quote
