Flats to su's emission questions. swapping balance bars?
Hi, After my RWC appointment one of the issues was emmisions, basically he said that because my car ran like a bag of shit he couldnt pass it for RW, so i bought some original 240 carbs with a e88 manifold from Zfactory. Now because my car is a 77 model it has to have emission crap on for the rwc. So what i thought i would do is swap the balance bars so i can still run all my emission points. Will this work? also there is a vacum line called the "Throttle opener control valve" Im still trying to figure what it is as i dont have a nipple to attach this vacum to. It picks up right next to the dizzy vacum. any ideas?
cheers
glen
put all the carbs and emmision gear back on as requested take a exhaust gas emmision reading then take it to get the rwc see what they do then , you tell me how would they know if a part wasnt functioning correctly, some times i wonder if you know what your talking about why act dum?
Dude I just read your last 3 posts. Have you got anything constructive to say? By the way you spelt dumb wrong!
Your missing the whole point, im not spending money on a emission test nor am i going to spend money on fixing some carbies that i wont be keeping. Im not removing any emission gear, if you read my post correctly im swapping the balance bar so i can still run the emission gear. The tunability of the 240 carbies is what i need to pass the RW. Even though ben (RWC Guy) wrote emissions problems on my sheet after speaking to him he said it was more the fact that the car was backing firing and farting all time. As for calling me dumb im not sure why you would say that but id prefer if you didnt respond to anymore of my thread questions as it appears you have alterior motives.
personaly dont see why you couldnt do it as long as it matches up. as for the erg solinoid  mine was running fine with it disconnected so i dont see it as an issue just give it a try and see if it works its not hard to change back to the original one
cheers pauly
