Dionysus Posted February 22, 2016 Share Posted February 22, 2016 Hi My oil cap appears to be leaking and since replacing an oil cap will cost $50+ I thought I would investigate whether there is a replacement O-ring that I can fit instead.. I removed the O-ring which appears to be hard plastic square with a step in it 32mm ID, 44mm OD and 5mm thick.. It's seen better days as it's chipped and dented.Worst case scenario I was considering trying to fit a standard O ring or possibly make something out of a gasket sheet. Anyone else resolved this issue in the past? ThanksJohn Quote Link to comment Share on other sites More sharing options...
Moderators PB260Z Posted February 23, 2016 Moderators Share Posted February 23, 2016 Hi, I would probably just look for a replacement cap with a decent O-ring from a parted out car. Maybe try - a wanted post - calling, Stewie Wilkins, James Flett or Warren at All-Z-Parts Cheers PB Quote Link to comment Share on other sites More sharing options...
Dionysus Posted February 23, 2016 Author Share Posted February 23, 2016 Thanks PB I also just found a 300zx oil cap o-ring and the measurements are very similar and might fit..I may try it and see how it goes first since it will only set me back about $15. Quote Link to comment Share on other sites More sharing options...
PeterH Posted February 23, 2016 Share Posted February 23, 2016 Do you want some good news??? I just had rang my local nissan dealer and part no, 15270-78500, packing - oil filler cap, is in stock in aus. I was quoted " about $6.50 " and most likely over night to Tamworth. The complete cap is still available ex Japan. Good luck Quote Link to comment Share on other sites More sharing options...
Dionysus Posted February 23, 2016 Author Share Posted February 23, 2016 That's great to hear.. So you called Nissan Parts Tamworth??I tried my closest Nissan Parts shop and the said it was not available..I Do you want some good news??? I just had rang my local nissan dealer and part no, 15270-78500, packing - oil filler cap, is in stock in aus. I was quoted " about $6.50 " and most likely over night to Tamworth. The complete cap is still available ex Japan. Good luck Quote Link to comment Share on other sites More sharing options...
PeterH Posted February 23, 2016 Share Posted February 23, 2016 Did you quote that part number? The parts guy here gave a disc with the old parts list. I think he got sick of me bothering him. He looks after me price wise but when I gave him the number he put it in the system and said " yep that's still good". Dionysus 1 Quote Link to comment Share on other sites More sharing options...
Dionysus Posted February 23, 2016 Author Share Posted February 23, 2016 will contact them again now.. Quote Link to comment Share on other sites More sharing options...
Moderators PB260Z Posted February 23, 2016 Moderators Share Posted February 23, 2016 Do you want some good news??? I just had rang my local nissan dealer and part no, 15270-78500, packing - oil filler cap, is in stock in aus. I was quoted " about $6.50 " and most likely over night to Tamworth. The complete cap is still available ex Japan. Good luck Sounds like your local Nissan dealer is more helpful than those at Hornsby Nissan. Have tried twice for common parts and each time the answer "No Longer Available" Quote Link to comment Share on other sites More sharing options...
PeterH Posted February 23, 2016 Share Posted February 23, 2016 The guys here have been good ...but have come to dead end with a lot of NLA parts..... drivers door mirror ....gear knob.... etc etc.... but they did find a new flywheel and a timing cover. Warren has been good at Hornsby..... as well as other suppliers Quote Link to comment Share on other sites More sharing options...
Moderators PB260Z Posted February 23, 2016 Moderators Share Posted February 23, 2016 Yeah, I have found Warren to be very helpful and he is only 5 mins from my place. Stewie Wilkins has also been a great source of not only parts but also advice. Quote Link to comment Share on other sites More sharing options...
Dionysus Posted February 24, 2016 Author Share Posted February 24, 2016 So I was referring to Klosters Parts Wickham who put the order it and was happy to post it out.. Thanks! Quote Link to comment Share on other sites More sharing options...
dat2kman Posted February 24, 2016 Share Posted February 24, 2016 Never ever tell them what the car s first. Tell them the part number, then afterwards, tell them its for a very very old Datsun, that Nissan used to make, probably long before the parts counter person was a twinkle in their father's eye,,,, Quote Link to comment Share on other sites More sharing options...
HKSZ Posted February 24, 2016 Share Posted February 24, 2016 haha when asking for door handle i always said its for a Datsun 1600, not a 240Z. Just take the O ring into a local bearing shop, nothing special about it probably cost 50c Quote Link to comment Share on other sites More sharing options...
PeterH Posted February 29, 2016 Share Posted February 29, 2016 Hi John...how did you go with the oil cap seal? Quote Link to comment Share on other sites More sharing options...
Dionysus Posted February 29, 2016 Author Share Posted February 29, 2016 Hey mate, they couldn't find the stock on the shelves but said they could get it sent from SA. I don't mind the wait so they said it should be shipped out today and receive it later on in the week. Will report back in when I get it. Quote Link to comment Share on other sites More sharing options...
PeterH Posted February 29, 2016 Share Posted February 29, 2016 OK I bought 2 from the dealer here...thought I should get one while I can.... here in two days. Let me know if you get stuck...I just like to use the right parts when I can.. Quote Link to comment Share on other sites More sharing options...
Dionysus Posted March 8, 2016 Author Share Posted March 8, 2016 Just a follow up.. The seal fits perfect and is rubber where as the old seal was a hard plastic.. Thanks for the help! Quote Link to comment Share on other sites More sharing options...
Moderators PB260Z Posted March 8, 2016 Moderators Share Posted March 8, 2016 Great news, and way cheaper than buying a complete cap. Happy Days Quote Link to comment Share on other sites More sharing options...
