Glen Posted February 25, 2008 Posted February 25, 2008 had a look at scorcher's but they are $500 with coil. Is a 280z plug and play or would i need a auto elec? I have replaced leads, sparkplugs, rotor button, points and a friend set the timming. it ran ok for a short time and then started backfiring and carrying on etc now its running like a sh!tbox again. so i decided on electronic distributor instead. Is there a less expensive ($500) distributors around? Quote
Moderators Zedman240® Posted February 25, 2008 Moderators Posted February 25, 2008 The easiest option is the 280ZX distributor, which is almost a "plug + play" upgrade. You will have to change coil to a 280 one and some minor rewiring to get rid of the ballast resistor. Depending on your loaction, I can either send you a spare distributor I have or come around and I can help you fit one. When its fitted, you'll find easier starting, smoother running and slightly more power! Quote
C.A.R. Posted February 25, 2008 Posted February 25, 2008 Or use the one off a R30 Skyline (L24e). Quote
Glen Posted February 25, 2008 Author Posted February 25, 2008 I just ordered a scorcher and then after reading this thread cancelled that order. Zedman240, im in Dromana, so that would be a 45 min trip for you if your still keen. How much would you be wanting for the dizzy and do you have the coil aswell or should i chase one of these up. I bought a indicator assembly off zworks but it turns out i dont need it. should i exchange this for a 280 coil. I appreciate the offer for you to come down but if its to far i can pick up from you. I have this week off from work trying to sort the car which im almost done Quote
Glen Posted February 25, 2008 Author Posted February 25, 2008 Or use the one off a R30 Skyline (L24e). sorry lurch i missed this, are they plug and play aswell, are they hard to source and what sort of $ would i be looking at paying for one with a coil. sorry about all the questions just need to tick all the boxes first. Quote
maddos Posted February 25, 2008 Posted February 25, 2008 The XR700 are a pretty good setup for less than $200. Had mine in for 18 mths without a drama. Took about an hour or two install not too stressful. Quote
Moderators Zedman240® Posted February 25, 2008 Moderators Posted February 25, 2008 No problem Glen73, The distributor I have is from an R30 Skyline. They are pretty much identical anyway. Unless the curve is different. Anyway, if you could source a coil I guess I can come up and give you a hand to install. Only takes around 1 hour or so. But as Murphy's law dictates; "what can go wrong will go wrong" heheh Or if you are down Moorabbin way during the week you can pick it up from me. If you want it for $50 its for the taking...If I have the time and can come up but it depends on how I'm going here. I'm in the middle of a coilover conversion again and time is against me! If you want to call me my number is 0413 243 760. Quote
Glen Posted February 25, 2008 Author Posted February 25, 2008 No problem Glen73, The distributor I have is from an R30 Skyline. They are pretty much identical anyway. Unless the curve is different. Anyway, if you could source a coil I guess I can come up and give you a hand to install. Only takes around 1 hour or so. But as Murphy's law dictates; "what can go wrong will go wrong" heheh Or if you are down Moorabbin way during the week you can pick it up from me. If you want it for $50 its for the taking...If I have the time and can come up but it depends on how I'm going here. I'm in the middle of a coilover conversion again and time is against me! If you want to call me my number is 0413 243 760. thanks mate thats great, i can drop by and do a pick up. I will get the 280 coil off zworks tomorrow and if its ok with you can i drop by pick it up then. I think i should get by installing it hopefully but you never know Thanks again you saved me a lot of money. cheers glen Quote
