blu260z Posted June 15, 2015 Posted June 15, 2015 Hi guys I am having trouble with door locks lately. I stripped the trim off and had a look.at the lock it was pretty stuffed, so I decide to look into buying some next locks. But my lock looks nothing like any locks I can find. Is the 2+2 locks differnt from 240z& 260z because of the extra internal door latch/handle. If so where can I find a set ? Or can I just swap the arms on the 260z locks Thanks guys Quote
CroS13 Posted June 15, 2015 Posted June 15, 2015 yes they are different, i had the same issue when i bought some thailand locks from ebay and they were completely wrong. If it was anything like mine, the slot in the tang that the lock barrel sits in has worn away over time and it just slips and wont turn the tang. What i did was weld up the holes and try my best to re make the keyway for the barrel to fit in. only other option is try and find someone wrecking a 2+2, but ive been to a few of them and they are all pretty much stuffed. Rudolf. Quote
blu260z Posted June 16, 2015 Author Posted June 16, 2015 I have ordered a new set of 260z locks from my local Autopro hopefully I can swap the arms over. Failing that I will cut the arms up and tig them to work Quote
Clockwork Posted June 19, 2015 Posted June 19, 2015 Let us know how it goes - mine are rooted too Quote
blu260z Posted June 19, 2015 Author Posted June 19, 2015 Ok so no surprise that the 260z locks I ordered where not the same as the 260z 2+2 locks But !!!! If you are capable of using a welder this can be an easy fix. Cut the new arm weld on the old. I will do a full HOW TO on the weekend and post it up because I am sure people will benefit from it. Quote
blu260z Posted June 21, 2015 Author Posted June 21, 2015 I have written a how to Click the link for a look http://www.viczcar.com/forum/index.php/topic,16176.0.html Quote
Azman1984 Posted June 21, 2015 Posted June 21, 2015 Hey guys, First thanks for the How to, I had a look at it this morning and might have to do the same. As a side question, could you use the standard 260 locks if you didnt want to use the 2nd handles in the 2+2? Quote
blu260z Posted June 22, 2015 Author Posted June 22, 2015 Hi azman. No the 2+2 has a totally different setup. Quote
Azman1984 Posted June 22, 2015 Posted June 22, 2015 Hi azman. No the 2+2 has a totally different setup. Sweet. Thanks for that. Quote
