Cant find replacement 260z 2+2 door locks, I have an answer...
I have Been chasing replacement 2+2 door locks for a few weeks now without any luck. I have posted on here and it seems others have the same issue so I have taken the time to write a HOW TO on using standard 240z/260z locks.
Level of difficulty 2/5 (if you can weld)
Tools needed/ hacksaw or grinder, ruler, finepoint sharpie, welder (mig or tig), file
Ok so you will need to purchase a set of locks from your local auto shop aprox $50
as you can see they look nothing alike to the original 2+2 locks
20150620_1228191_zpsjmau30ef.jpg~original
20150620_1230451_zpsng4i0hf9.jpg~original
You will need to remove both of the arms and mark a line 16mm from the end on both. This will be your cut line.
20150620_1234481_zpsfv3p24nr.jpg~original
I recommend cutting with a hacksaw but to the butchers out there you could use a grinder. Now clamp and tac part A and B
20150620_124230_zps2saovqqt.jpg~original
20150620_1247101_zpszbbzw3ph.jpg~original
Now test fit the lock make sure it engages and obviously unlocks the door.
Once you know it fits and works you can weld and flush back with a file. Replace the rubber on the arm now I used some vacuum line.
hey presto a brand new 2+2 lock  :)
20150620_1258281_zpsretk0gu2.jpg~original
Hopefully this can help out some 2+2 owners experiencing the same issue  :)
Regards BLU :)
Thanks for sharing this tip. It's what makes the site so useful.
