slow l2.8 Posted April 20, 2015 Posted April 20, 2015 I recently did a compression check on my l28 and she is low in compression 73psi across the lot oiled around 190 psi so I want a replacment engine with a bit of work as its going into a patrol let me know what you have closer to Vic the better Thanks for you time Quote
C.A.R. Posted April 20, 2015 Posted April 20, 2015 I've got a reconditioned L28 here with a mild cam & a cleaned up head. 0 Hrs. I just have to finished bolting the head back on etc etc. $6200.00 Quote
44014 Posted April 21, 2015 Posted April 21, 2015 I've got a reconditioned L28 here with a mild cam & a cleaned up head. 0 Hrs. I just have to finished bolting the head back on etc etc. $6200.00 Does that come triples and swm headers Lurch? Will it do 250hp at the fly? Quote
C.A.R. Posted April 21, 2015 Posted April 21, 2015 Does that come triples and swm headers Lurch? Will it do 250hp at the fly? I'll assume you're bring serious Doug... 1. No - Long motor only. 2. No idea. It's just a spare I'm building up. Quote
dat2kman Posted April 21, 2015 Posted April 21, 2015 Also have one here, bit more in it than Lurch's Knife edged crank, steel flywheel, solid centre button clutch, BHJ Balancer, full snout keyway, forged rods forged pistons, heavily ported and shaved head, 74deg cam, new valve springs, new valves and guides. Larger cap winged sump, high vol/pressure oil pump. No induction/exhaust. All items brand new, including fresh block machining. Ready to Assemble Ex Group S race engine ( spare) $8000. plus freight Quote
