For a camshaft & If you mean for an L series, Crow cams still list a good "street" cam. Most of the big boys like rocket Ind should have access to Crow cams.
Bugger , how did that happen ?
I have a healthy sized cam with lash pads and rocker arms to go with it for sale?
Cam is a Ivan Tighe 369C that i have just installed and basically run in only.
Driven car 7km with the cam in the car was brand new when installed.
Still in car only selling as have just purchased a L28 injected turbo set up.
$350 plus postage.
Will need to get short valve stem seals and aftermarket springs due to the amount of lift exceeds the stock springs capabilities.
Cam pulls from 3500-4000 ish rpm I have revved my engine to 7500rpm and it was showing no signs of running out of puff and has a nice lumpy idle.
Cheers Doug
Link to cam specs
http://tighecams.com.au/profiles3/nissanlseries.htm
For turbo application you dont want big durations. Maybe have the intake open and close a little later.
Have a read of the Racer Brown guide to camshafts, he covered boosted applications.
Ahh Didn't take in the fact he is doing a turbo conversion.
yes my cam would be no good as all your boost will blow out the exhaust.
Yes, but that would look baller out the exhaust,,,,
scraping the turbo idea for now i wana drive the thing so any n/a cam yours may be a bit crazy looking at maybe 72deg and 74deg cam from swmotorsport
You're in Melbourne, go straight to Clive Cams.
A nice streetable 72 degree regrind on a stocko cam, or a little bit more aggressive, a 74 degree on a blank, to get the lobe centres right.
Clive bought out Wade's, he knows his stuff.
We call it the man cam, are you man enough? Ha ha.
It's not to bad off can still has reasonable performance but would need triples and a good exhaust as minimum to run it.
